Odd problem with TF2
20 Oct 2002
North West
When playing on MPUK servers I'm getting massive choke and sometimes loss. I've pinged the server VIA command prompt and I'm getting no loss and good pings :/
Maybe you need to increase or decrease your network settings in the console
I use:
rate 50000
cl_updaterate 100
cl_cmdrate 100
But maybe lower them if the server you're on can't handle it.
lag on hl2 is screwy and has been for over a year, best thing you can do is alter the server you play on and try and find one that matches your connection well.
Tic rate is one factor, ask admin what it is for a clue
I just made a read-only autoexec and put in 10000 for rate and 100 for update and cmdrate.
Now I'm getting mad choke :/
I would try lowering your two cl_ values 10 at a time, until the choke stops. Best case is highest values with lowest choke.
Lower 'rate' at 1000 each time.
The good thing is in TF2 choke/loss doesn't matter so much.
Lots of info:
http://developer.valvesoftware.com/wiki/TF2_Network_Graph
Also, make sure you try other servers to eliminate problems there - It might just be the ones you're trying are bad servers/on bad connections/overloaded servers.
The problem is I also seem to be getting animation stutter on my weapons - which doesn't happen when I have 0 choke/0 loss.
I thought I'd fixed it by rebooting my router...but it's back in force.
