Odd question, tft wipes
Can't type for toffee
Don
14 Jun 2004
Newcastle U/T
Recently purchsed a HP W2007, lovely monitor.
Has a gloss finish to it and I was wondering which wipes would be best.
Tried a damp cloth and it just made streaks.
Ive heard the alcohol based ones can dmage the coating.
So which are worth using that will do the job and not smudge/streak?
Thx in advance
Have you read the monitors FAQ sticky? It has a bit about cleaning in there. I'm not sure if there are any purpose made wipes available.
i bought some so called "anti-static screen wipes" made especially for tfts and they are crap. they leave a right mess behind.... :p
