Odd Samsung Monitor Issue
3 Oct 2011
Hi All :)
I was wondering if anyone else may have had a similar issue with their Samsung Monitor being stuck in a "Store Mode", it flashes that its in this mode across the screen every 10 minutes that is in Store Mode then flicks through all the various settings. Its been doing this for about a week and I am not sure which key combination I accidentally pressed to get in this mode. :confused:
Its a Samsung S24A300BL and I think I've tried every suggestion google has to offer/studied the manual for any clues and even talked to Samsung Support who seem just as confused as me (and keep offering me solutions for other monitors). The normal "reset" on the OSD doesn't seem to clear it either.
Any ideas? As its out of warranty, Samsung seem to just be directing me to a service centre.
Thanks for any suggestions/help :)
I forget which, but try holding down the 'left' or 'right' key for 10 seconds or so.
Tried them all (and for longer!) individual and in combo! Nothing seems to work. (Liked Samsung Supports suggestion of using the menu key, which just locks the OSD).
Thanks anyway! :)
