Wanted to get some thoughts on a problem I've had.
I've had a new Seasonic 850w Prime TX's Titanium's delivered recently. (which was then RMA'd).
Both came out the box with an odd fault condition.
System Boots to windows, as soon as Windows Initialises the GTX1060, black screens, fans ramp up to full speed and just sits there doing nothing with fans spinning. If I boot into the BIOS, it'll happily sit there for an hour without issue.
A quick multi-meter check on a Molex shows 12v and 5v rails are spot on when the issue occurs.
Swap over to an older Corsair RMx 650 watt unit, system boots without issue.
It's almost as if one of the rails is resetting.
Anyone seen behaviour like this from a PSU before?
Systems as Gigabyte Aorus Master X570 / 5900X / GTX1060. Not a heavy load by any means
Guess it could be a bad batch but would be curious if I've missed something obvious. Never had a PSU react in this way before as if it's perfect, but not.
