Hey all,
Have my side panels off whilst waiting for some parts from OCUK and noticed a slightly odd sound when GPU is under load. Tried to record it for you but unable to pick it up on phone or headset microphone.
It sounds like a mixture of white noise and that classic disc HDD whirring sound. For reference I have an M2 SSD and SATA SSD, other components listed below.
CPU: Ryzen 5 3600 @stock with EKWB velocity block
MB: Asus Prime B450m-a
RAM: 4*gb Corsair DDR4 *2800mhz
GPU: MSI Mech OC RX 5700XT with Bykski A-SP5700XT-X block
PSU: Corsair RM750X
Pump/res: Corsair XD5 RGB
Rads: 1*alphacool 240mm 1*EKWB 360mm with 5*thermaltake pure A12 120mm fans @700rpm
The sound is either directly from the GPU or the PSU and I'm not sure if I ought to be concerned. I've had coil whine before from a PSU but it doesn't sound like that. I'm not exactly sure how the GPU could make such a sound? I normally play with a headset on and so I've never heard this sound before - it may be exaggerated because of how quiet the overall build is plus the side panels are both off.
CPU temps rarely over 60c and GPU around 50c.
Thanks in advance,
Matt
PSU: Corsair RM750X
Thanks in advance,
Matt
