So having put my new build together (in sig), I found some rather odd issues with turning my pc on. It still works but it's kind of annoying.
If I am turning the tower on for the first time since switching it on at the wall, it will briefly start with lights and fans going for about a second, then power down again for about 3 seconds before starting up as normal.
Is this a problem? What might be causing it?
Also, kind of similar when it is turning on, the mobo screen will come up, then a black screen with white writing where it will tell me, no hard disk found! then go back to mobo screen and boot up normally from there. Is it a problem? And even if it isn't, what could I do to solve it? It's pretty annoying.
Just in case this is relevant I think I remember plugging the HDD into the SATA3 slot, and optical drive into SATA1, and thought this might be causing the second issue, but was afraid of switching them around in case it stopped detecting the two pieces of hardware correctly.
Thanks. If you need any more details of specifics just ask, I could take photos of all the things I've tried to describe if it's necessary.
