Odd temps after watercooling
24 Feb 2009
Teesside
Just watercooled my GTX275 and figured I'd test it out, see what sort of clocks I can get on it. Straight away I could see it was running better but then noticed these strange temps kept flashing up in GPU-Z. Set it to show max temp and min temp and look at the results...
The top 2 for GPU and PCB temps are fine, the bottom 2 are going nuts! They used to display pretty much the same temps, maybe 1 or 2 degrees out. Or does anybody know why theres 2 sets? Meant to be for SLI/Crossfire and it just goes wierd with only 1 card?
Why do you care?
Quick tip: if you're happy with the temperatures shown in the top two sensors, ignore the ones below.
Quick tip #2: if your machine is stable, stop monitoring the temperatures and congratulate yourself on a nice machine.
Really, life's too short.
Lol, fair answer! I was just curious about what they're meant to be monitoring. They were fine before I went to watercooling so was wondering why they'd suddenly just gone a bit nuts!
