Odd TP Link Powerline issue
27 Aug 2004
UK
I have a pair of TP Link PA-201 home plugs, which have been flawless for the last year or so.
This morning I've installed a new SSD and Win 7, then used the supplied TP Link disc to install the utilities. The management tool however says 'HOMEPLUG NOT DETECTED'. I've tried rebooting, uninstalling, using the latest versions from the website - no luck.
When I put the old SSD in, everything works fine, so it's not a hardware/cable issue.
Any pointers?
did you press the reset button? I had similar problem with mine so pressed the reset button fo a few seconds and mine worked fine again
