Odd voltage
31 Jul 2005
Edinburgh
I've been keeping an eye on my voltages and fans n stuff with MBM5 all my voltages are pretty much spot on except for the -5v which is reading 3.55v. (The +5 is spot on) Could this cause any problems?
Are you sure you don't have MBM5 monitoring the 3.3V rail?
Download something like Everest (google for the Home Edition) for a comparison.
Depending on the mobo , MBM5 can confuse certain readouts
On my DFI NF3 it displays the LDT Voltage under the Chipset and vice versa.
As above suggestion , use Everest to confirm.
Cheers,
Mark
iirc the -5 rail should read between +4.8volts and +5.2volts.. anything outside that i believe you may start having a few unpredicable problems.
What Mobo do you have..
It's always best to spec your rig whenever you post a problem unless it's to do with your gf in GD in which case pictures are a must :D
