I bought a HISENSE 40 inch 4K Ultra HD Smart TV at the week end I have connected to it a Humax HD Fox T2 PVR connected via HDMIand a Q Acoustics Q-TV3 Compact soundbar which is connected via a toslink optical cable.
With these connected and the TV speakers either turned off or muted I should be able to control the TV volume using the PVR remote control. Or this is how it worked on a Samsung 32F5000 this TV replaced.
Now his is the problem the remote volume control will work on every channel bar the HD channels for that I need to use the soundbar remote.
User manual that came with the TV did not think to include a section on what the various setting do under various heading though quite a few are obviously self explanatory.
So far I have contacted the firm who supplied the TV, he is going to speak to his tech guy and get back to me.
I contacted Q Acoustics and spoke to a tech guy and thought that perhaps it was a compatibility issue but that I should speak to Hisense.
I have contacted them and await a return call from their tech guy.
Any one any thoughts?
