Odd vSphere issue - XP Remote/Console window will not restore
31 Mar 2006
Sydney Australia
As the title really. I have an XP Pro box installed in vSphere that works fine right up until the point that you minimise the remote/console window, then it will not restore. All my other servers are fine, unfortunately none of the other ones are XP but all will minimise and restore just fine.
I've tried updating VMWare tools and also checked the VM specific video driver and it is using the VMWare tools one. Kinda stumped really.
Again - VM is XP Pro
Desktop with vSphere installed is W7 Ultimate
vSphere version is 4.1.0
vCentre is 4.1.0
Any help is appreciated, I can't find anything in the VMWare forums or via Google.
Why not just RDP? or download RSAT and rattle up a remote desktop MMC for all your physical and virtual servers and XP?
I only use vSphere to set IP and join the domain.
Just download Remote Desktop Connection Manager, it's much simpler:
http://www.microsoft.com/download/en/details.aspx?id=21101
You shouldn't even need to do that. Create yourself a Customisation in Customisation Specifications Manager and vSphere will automatically join the virtual to the domain and implement an assigned IP address.
I don't really use the remote console if I can avoid it, RDP is far easier to use.
Expecially as in 2008 even with VMWare tools isntalled the mouse cursor is still horrific compared to XP and 2003 :( (this is on a windows 7 machine mind, it could just be a client bug)
