- 19 Feb 2007
- Northampton
How many times can you install an oem version of windows on the same machine just say the hdd goes funny.
And hopefully you can re-use the key in such an event...
That's true of Vista, but with XP you can get away with changing everything over time and not have any problems re-activating the license.You could change everything in the system except from the motherboard, reinstall using the same key. It is tied to one motherboard.
but you'll be unlicensed... being activated and being licensed are two totally different things.That's true of Vista, but with XP you can get away with changing everything over time and not have any problems re-activating the license.
