Epitaxial said:If I want to fit my own CPU cooler then am I right in thinking that I need the OEM or are there any other considerations (I am thinking here of AMD 939 FX and X2)
Many thanks
mike
Teknodeamon said:oem all the way!
Stelly said:I thought that retail gave you better overclocks??
Stelly
Stelly
Like said above. But noticed that price difference between OEM & Retail on some chips is negligable. So, better to just go retail. I think you also get a nice little sticker with Retail (apart from the nice packaging also)Minstadave said:OEM is cheaper, only has 1 year warranty.
Retail is more expensive, but you get the heatsink and 3 years warranty.
hp7909 said:Question: If you use your retail chip with another heatsink apart from the supplied one does it void your warranty?
