That's what Im afterwould you mind telling me where? uncle G couldn't help me...
People buy retail for the warranty.
Retail warranty is 3 years, OEM usually 1 year.
Found it![]()
qbadz can you mail me thru trust.
LOL...
Wouldn't o/cing the CPU (even by the multi) validate the warranty if it was found to be fried?
And if they say that QC on the new SB is so strict (especially for the K versions) then I guess these should be flawless and any problems are user error which would not get covered by the warranty.
Only found the 2600K in oem so far.
These are just guidelines we recommend you follow, if you want to push more voltage through your CPU's then just be aware they could die on you. Your warranty is un-affected and we will honour any CPU's that die, we just won't ask questions as to how you killed them.
Not all CPU's are as fragile as others, we have experimented upto 1.50v Vcore and 1.70v memory and had zero issues with reliability, so it seems some of fine when pushing hard.![]()
Wonder why ocuk hasn't stocked these yet, I doubt many early adopters to Sandy Bridge would be using the the oem cooler especially the k range.
MW
