I don't even need to say much about this really do I?
Corsair Hydro H90 280mm High Performance Liquid CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM3) (CW-9060013-WW) @ £69.98 inc VAT
Low noise, high performance CPU cooling
Hydro Series H90 is a 140mm all-in-one liquid CPU cooler that provides better cooling with lower noise than other high-end liquid coolers. Liquid cooling simply works better than air cooling, and the self-contained design of the H90 makes it easy for you to protect your valuable CPU.
Take advantage of your 140mm fan mount
For efficient cooling, bigger is better – it’s simple physics. If your PC’s case supports 140mm fans, Hydro Series H90 will give you better performance. The larger diameter fan has better airflow with lower noise than most 120mm fans, and the 140mm radiator has more surface area for faster cooling.
140mm radiator
The 140mm-wide radiator has a larger surface area than typical 120mm radiators for more efficient heat transfer.
Low-RPM 140mm fan
The blades of the included 140mm fan are larger than most 120mm fan blades, so it doesn’t need to spin as fast to deliver the same airflow.
Next-generation tubing
The low-evaporation, easy-bend tubing is guaranteed leak-free.
Advanced cold plate and manifold design
The cold plate uses copper for outstanding heat transfer, and the manifold is engineered for efficient flow.
Simple mounting bracket
The multi-platform mounting bracket easily adapts for Intel and AMD processors.
Package contents
Corsair Hydro Series H90 High Performance Liquid CPU
Mounting kit for all modern CPU sockets
140mm High Torque Fan
Fan and radiator mounting screws
Thermal compound (pre-applied)
Quick Start Guide
Technical Specifications
Radiator dimensions: 140mm x 170mm x 27mm
Fan dimensions: 140mm x 25mm
Fan speed: 1500 +/- 10% RPM
Fan airflow: 94 CFM
Fan static pressure: 1.64mm-H2O
Noise level: 35dB(A)
Compatibility
Intel LGA 1155, 1156, 1366, and 2011
AMD sockets AM2, AM3, FM1, FM2
Was £92.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Corsair Hydro H110 280mm High Performance Liquid CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM3) (CW-9060014-WW) @ £94.99 inc VAT
Extreme CPU cooling performance
Hydro Series H110 is an all-in-one liquid CPU cooler that provides cooling that’s far superior to stock CPU air fans. Liquid cooling simply works better than air cooling, and the self-contained design of the H110 makes it easy for you to protect your valuable CPU.
Take advantage of your 280mm radiator mount
For efficient cooling, bigger is better – it’s simple physics. If your PC’s case can fit a 280mm radiator, Hydro Series H110 will give you better performance. The larger diameter fans provide better airflow with lower noise than most 120mm fans, and the 280mm radiator has more surface area for faster cooling.
280mm radiator
The 280mm-wide radiator has a larger surface area than typical 240mm radiators for more efficient heat transfer.
Low-RPM 140mm fans
The blades of the included 140mms fan are larger than most 120mm fan blades, so they don’t need to spin as fast to deliver the same airflow, reducing noise without lowering performance.
Package contents
Corsair Hydro Series H110 High Performance Liquid CPU Cooler
Two 140mm High Torque Fans
Quick Start Guide
Radiator dimensions: 140mm x 312mm x 29mm
Fan airflow: 94 CFM
Compatibility
Intel™ LGA 1155, 1156, 1366, and 2011
AMD™ sockets FM1, FM2, AM2, and AM3
Was £119.99 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
140mm radiator
Low-RPM 140mm fan
Package contents
Quick Start Guide
Fan airflow: 94 CFM
Compatibility
Was £92.99 Inc. VAT
ORDER NOW
280mm radiator
Low-RPM 140mm fans
Package contents
Quick Start Guide
Fan airflow: 94 CFM
Compatibility
ORDER NOW
