My youngest brothers been offered 2nd hand E6750 for £60 on a 'mates rates' basis
He's current pc is socket 939 based so an upgrade is long overdue. I was about to build him new pc using either E4500 or E2200, inc decent motherboard and some cheap PC6400 memory; as I figured the 11x multi on both those cpu's would allow plenty of headroom over clocking wise (+ his current Tuniq cooler).
Might sound silly to even ask opinions on this, but I know nothing about over clocking E6750 (good oc, bad, all GO revision?), however have plenty of experience with the other two cpu's. Total cost for either upgrade work’s out about the same inc the additional parts.
He's current pc is socket 939 based so an upgrade is long overdue. I was about to build him new pc using either E4500 or E2200, inc decent motherboard and some cheap PC6400 memory; as I figured the 11x multi on both those cpu's would allow plenty of headroom over clocking wise (+ his current Tuniq cooler).Might sound silly to even ask opinions on this, but I know nothing about over clocking E6750 (good oc, bad, all GO revision?), however have plenty of experience with the other two cpu's. Total cost for either upgrade work’s out about the same inc the additional parts.
. with the 8400 dominating though, does this chip still have worth???
