Office 2003 / 2007 question
18 Oct 2002
Pembrokeshire
I have a friend who has to upgrade his excel to 07 to be able to use a particular file for work. However, he wants to be able to retain Word 03.
When upgrading Excel, we have tried to tell the installer not to uninstall Excel but unistall all the others and only install Excel 07 making the others Not Available. When it goes to install it says theres a cab file missing SKU112.CAB and the install fails. This Cab file is an 03 file though.
If it comes to it we can install 07 complete but he doesn't want to because he hasn't really got time to re-learn Word.
Can't you just install word and turn off the ribbon?
I thought I read somewhere ages ago that you could do this although I personally don't know why you'd want to.
Edit: Just did a quick google search. Seems there's an add-on called Toolbar Toggle that installs the 2003 toolbar in place of the ribbon.
Don't know how good it is though.
If it is just a docx file you can download a conversion pack for Office 2003 which will open them.
As for having to "re-learn" Word he really should try it - I bet it could have easily gotten to grips with it in the time he's had you faffing around. ;)
Costs $19.99 for a 'Single User Licence'... I'd stick with the Ribbon :)
Yeah I noticed that on the site.
New things must really scare some people.:)
The docx convertor mentioned above is the best bet. I installed that on my work PC that's still running Office 2003 and you don't even need administrator priviliges to put it on.
