15 Jun 2006 at 19:33 #1 MichaelHo MichaelHo Associate Joined 19 Jan 2006 Posts 1,252 Location London, UK can some1 confirm that windows ms office 2007 files will work with office for mac?
15 Jun 2006 at 20:13 #2 ic1male ic1male Caporegime Joined 28 Oct 2003 Posts 32,841 Location Chestershire Should do if the Office 2007 user saves them as 97-2003 compatible rather than the new XML format.
15 Jun 2006 at 20:56 #3 spirit spirit Associate Joined 18 Oct 2002 Posts 1,884 if you are usign the beta version, thes a bug with the compatability btw.
15 Jun 2006 at 22:48 #4 MichaelHo MichaelHo Associate OP Joined 19 Jan 2006 Posts 1,252 Location London, UK spirit said: if you are usign the beta version, thes a bug with the compatability btw. Click to expand... theres only the beta version available isnt it? if i save all my office 2007 files as 2003 files, they should work?
15 Jun 2006 at 22:49 #5 MichaelHo MichaelHo Associate OP Joined 19 Jan 2006 Posts 1,252 Location London, UK i want to get a mac soonish but i have some important work i need to finish off on word and i need it to work with mac office.
17 Jun 2006 at 13:58 #6 Caged Caged Man of Honour Joined 18 Oct 2002 Posts 26,974 If it's important, why are you using a Beta of Office 2007?
