Office 2010 Questons.
9 Dec 2006
@ManCave
I'm looking to buy Office 2010 to allow me to work on my Projects for work at home. i normally use OpenOffice but its not sufficient any more as i'm now using a lot of VB coding which it doesn't like.
Now Whats the difference between Home/Student & Home Business it just the extra outlook software?
Will 2010 play well with the Macros & special coding in my Office documents made in 2003 & work the other way around to?
hope you can help :D
As far as I know it's the same. It might be worth asking your IT department to see how you stand with work at home licensing, you might be able to bag works version for nothing.
or if they're on a VL agreement, you may be able to bag a copy for £8-9 on the Home Use Program like i did :)
