- 23 Sep 2015
Hi.
I've recently taken on a temp assistant in my studio and I'm looking to put together a PC which she can use for general office admin - basically running Lightblue and Office.
However, over time I'd like to have her start doing some processing of shoots.
Ideally I'd just build a nice PC that could comfortably handle the imaging side of things (Lightroom, CS and that's about it). We're a MOR studio, so no major high end retouching or massively large stacked images.
I wanted to see if it's economically feasible to build a PC that will do the basics and then upgrade components as and when required.
Is it just a bit of a false economy to build a lesser powered system which would need upgrading later on?
If so, can someone suggest a system that would run Lightroom and Photoshop at a fair clip (exporting on LR for example takes an age on my current processing PC due to it's naff processor)?
I'd probably be looking at a budget of around £450/500 ex OS and monitor.
This is what I put together as a start, OS/software on SSD, images stored on Seagate.
The SSD will have very little on it, just OS, LR, CS, Lightblue and Office.
Suggestions?
- Aerocool DS200 Black/White Edition
- Asus B85-PLUS Intel B85 (Socket 1150) DDR3 ATX Motherboard
- Intel Pentium K Anniversary G3258 Socket LGA1150 Processor -
- Seagate 2TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM
- Kingston 120GB SSDNow V300 Drive SATA 6Gb/s 3 2.5"
- Aerocool Strike-X Army Edition 500W '80 Plus Bronze' Power Supply
- Kingston HyperX Fury Black 4GB (1x4GB) DDR3 PC3-12800C10 1600MHz Single Channel Kit (HX316C10FB/4)
Suggestions?
