Office PC Build
17 May 2013
Is it possible to build an ok system for £200? Most likely matx
Needed:
CPU
MOBO
RAM
PSU
Case
Planning to run the monitor through the MOBO. Already have a Hard Drive and OS.
Basically needed to run a database, check emails, open attachments, word processing etc.
I have a build in mind but want to see what you more experienced users suggest.
Thanks. :)
In the end, I went for this. Turned out I did need a HD but went for a small SSD as everything in the office is ran on a server,
AMD A-Series A4 4000 Trinity Socket FM2 3GHz 1MB L2 Cache Retail Boxed Processor
CIT Shade MicroATX Case Black Interior with 500W PSU
Gigabyte GA-F2A55M-DS2 A55 Socket FM2 VGA DVI 7.1 Channel Audio mATX Motherboard
SanDisk 64GB Pulse SSD - 2.5" SATA-III - Read 490MB/s Write 240MB/s
TeamGroup Elite 4GB (2x2GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED34GM1600HC11DC01)
SuperFlower Amazon 300W "80 Plus Bronze" Power Supply
