Office/programming PC for ~£1000 and a monitor recommendation
24 Jul 2023
London
Hey folks, can you help me with a PC build, please? It will be used for office work, programming, maths (GeoGebra, SageMath) and maybe some light indie games.
I've just started my coding journey, so I don't think I'll touch any GPU programming any time soon. All I need is enough RAM and CPU power to handle VSCode, Firefox, and my maths software open at the same time. Also, I'd like to play with some virtual machines, so I think 32GB RAM is the minimum.
I'll also need a WiFi since I cannot use a cable. A small case would be nice, but it's not necessary.
And last but not least, can you recommend me a good monitor (~ 24") which won't cause a much of eye strain after hours of looking at it?
Thank you in advance!
Are you using GeoGebra locally or is it web based? SageMath will use multicores but I see that web based GeoGebra uses JS and is more dependent on single core performance whilst running it local will use multicores?
Also, will the £1000 include the monitor?
My basket at OcUK:
Total: £761.87 (includes delivery: £7.99)​
Add case and monitor.
I got a 7900 for dev work recently and been pretty impressed with it, 12 full fat cores and no silly power consumption/heat generation.
If the included iGPU is enough for your Indie games, that is a great spec. If not, you would need to bring it back to a 7600 (saving £180) and add a RX6000 for around £180-£200.
I would add this 32" 1440p LG 165Hz VA monitor LG Monitor FOR £230 which takes you right upto £990 and then a case that tickles your fancy (£30-£50). These will usually only come with a rear cooling fan so I would add a couple of 120mm for about £4 each
All in about £1030 - £1050.
Hope that helps.
Which software is this?
I can recommend the Lenovo L28u-35 4k monitor. It's a 28" 4k monitor. Only 60 Hz but supports Freesync / VRR and you can play your games at 1080p.
I think you mean a RX 6600 - a fine choice.
Have you looked at NUCs?
BTW you've chosen a lofty moniker. You might want to change it to something less presumptuous.
I run GeoGebra locally.
Edit: I forgot to mention that the £1000 is just for the box.
£1190 with the monitor excluding the case of your choice (£940). The cooler @Tetras recommended is fantastic but if you want it all in one order, take the Alpenfohn.
This MB has the Wifi you wanted and I swopped in a 600w Gold Modular PSU. His PSU is much better and you do have the budget to swop out. Just select your case of choice and install the two extra fans in the basket. If you find that you want the GPU, swop out the Ryzen 7900 for a 7600 and get the Asrock RX6600 for approximately the same total
My basket at OcUK:
Total: £1,189.84 (includes delivery: £0.00)​
Whatever your build please don't buy a Kolink power supply they only make one decent range PSU that's platinum rated.
You ideally want gold rated with a 7 to 10 year warranty.
I don't disagree per se but for his uses, it should work fine. It is C-Tier rated and Gold Modular. The 700w version got a "Great Value" award from Techpowerup Kolink 700 Enclave Review but I did mention the Seasonic is a much better choice.
OP just has to decide if we are including a GPU or not or a case or not as that is £260 right there.
