think it would be possible to purchase these seperatly so i can lump them into my 900? ive got filters but its very crude
I'm thinking of switching to watercooling and am seriously considering this, will there be enough room to mount the rad at the top of the case?
think it would be possible to purchase these seperatly so i can lump them into my 900? ive got filters but its very crude![]()
This case is some gooood stuff!
Quieter than my last case and cooler!
Working on it was easy as pie and the cable managment was very good.
Only bad points I can point out are...
Noisy with all fans on full (well duh!)
I forgot to put the screws back in the HDD caddy.... doesn't matter to me as I have a new HDD to fit but might annoy someone else if they forget
Couldn't fit a side fan on the window with my TRU. Had to cut half a corner off the fan to make it fit
Kinda heavy with all your bits inside... Although this could be seen as a good thing as it will be harder to steal!
Other than those little things everything else on it is amazing.
Hopefully get some pics up tonight... just need to find somewhere DECENT to host them...
Cheers, Doug.
Look forward to seeing your pics...
ImageShack are a good hosting site for pictures.
For those of you that have this case already does it come with an adaptor to convert an external bay into a 3.5" bay? As a review I read stated that theirs didnt but Antec promised it would be included with the full retail release version?
Thanks![]()
There's tons of room. In my last case my molex connectors only just fit in but in this one there is ample room.
I haven't finished tidying the back yet as there is some duct tape to go in there yet and a bit more tidying to be done.
Here's a pic:
One thing you will need with the Corsair 620HX is this
Luckily I ordered one before hand just in case![]()
Have you got any pics showing the front of the case with all your components installed...
tried my thermochil p120.2 and its far too big to fit internally on the rear two fans. Lucky I had still got a swiftech 240 rad and that seem to fit ok. Not too sure if I am even going to use this case for a build now as I really wanted to use my thermochil rad.
