Official MS Advanced Scart Cable
15 Aug 2003
Kirk Langley
Has Microsoft stopped making these?
The reason I ask is because I bought a second 360 today for use in the front room, the current one is in the bedroom and used with an LCD. The TV in the front room is a huge CRT and its still in great nick so seems a bit silly to ditch it for now.
Anyway in order to get the best picture I can on it I would need an RGB scart cable, preferably the MS one. I know you can still buy the venom and mad cats ones from various places on the net but I want the MS one and have hunted high and low for it and no one seems to sell it locally. Also I've only seen it on the net at silly prices.
Probably obvious why they are hard to find but it's annoying none the less.
If 2nd hand is an option for you then they can be had for £4 form high street type of place, obviously can't say exactly where as it is a competitor.
rp2000
I looked in all the high street shops I could think of and couldn't find one pre-owned either. :/
I had the same problem. Eventually I bought a genuine Microsoft one, but to be honest I couldn't tell any difference from the component cable/scart adapter that ships with console, although that could be because of my TV or my eyes. If you still want one, and are passing through Stoke at any time I'll sell you mine for £10 (to much hassle to post) as I now use HDMI.
