Can you connect this to your PC by plugging in the charging dock via USB with the headset connected? Or can you only use it on your PC using Bluetooth?
If you plug in the dock it just charges the device, if you plug in the headset it recognises it as a new device but i cant find any drivers,
It is a standard Bluetooth headset so you need bluetooth on your machine I have tested on 2 pcs and it works fine on them. Does your machine not have Bluetooth on it?
rp2000
Be warned you have to re-pair it with the PS3 after you've paired it with another device, this only takes 1/2 a second though as you simple need to plug it into the PS3 via USB and it's done.
Possible problem on your computer? (I know the wireless keypad is a BT device that only pairs with one machine at a time, are you thinking of that?).
Sorry to bring up an old thread, but can anyone enlighten me as to where I can buy one of these for a reasonable price. They seem to be sold out everywhere and the places which do have them in stock are ridiculously priced.
its best to get it with socom confrontation
can be had around £32 ish new and sell the game if its not your kind of thing
theres no point picking up a used one from auction eeeewww
[timko];14033785 said:End War with headset for £18 delivered was a good deal on Tuesday just gone. Stock of it sold out by the afternoon and no more orders can be placed.
