Hi maybe someone here could help , mine 2600k does 4.6 @ 1.34v stable , but when it clocks down to idle voltage , is not enough to power idle clocks and can blue screen .
so now im running 1.36v it makes my idle volts bit higher.
is there anyway to increase idle voltage in offset mode? or should i just don't bother and use 1.36v for 4.7 or 4.8ghz ?
thank you
thank you
