offset vcore with p8p67-m
26 Jun 2011
Hi today I simply set my mono to default and following a guide on the Internet that I have used before tryed to just get an oc of 4Ghz (I have an i5 2500k) I set the multi to 40 manual but with the p8p67-m it only allows me to offset vcore I'm not sure how this works?? I managed to get the oc at 4ghz but the vcore I could only manage to get around 1.23v ish with a -offset set at around 0.155. The guide I follow says to use a vcore of 1.12v now I tryed going further with the offset to 0.170+ but I get constant restarts or a bosd in this instance so I'm a bit miffed as to how I'd achieve the right vcore ?
I am fairly new to ocing so all advice in the simplest of terms would be greatly appreciated.
Thanks.
