Wifes car needs a fanbelt. So i nip off to the local motor factor in my SJ, on the way it developes a SERIOUS fuel problem, bunnyhopping and stalling. It wouldn't rev out and it was only the momentum i gained on a downward hill that kept it from stalling. Until i reach the bottom and it flattened off, when it died.
It would start for a few second, then die. If i touch the gas, it dies instantly, it ticked over for about 10 seconds if i leave the choke out then dies.
I bussed it to the motor factor and picked up a few screwdrivers and a can of carb cleaner (took ALL my tools out a few days ago to help a mate move a telly, duh)
Popped the top off the float chamber and it was nearly empty, so i turned the engine over and pumped fuel directly into the chamber. It started for a few seconds again but still died, without the level of the fuel going fown.
Which says blocked jet to me. So i dump a load of carb cleaner into the area to dislodge anything big and try the "rev it hard and block the air inlet" to pull anything through with a bit of vacuum. Which was tricky as the engine only really showed any life when i was cranking it over.
Things seemed to be going okay, it was spluttering a bit which hopefully meant things were clearing out.
And then the smoke started to rise from the starter. Which now only goes "click click" when i turn the key. Also my dash lights now only come on when i'm cranking :?:
Of course it all comes at a time of the year when we've got as lot of spare cash too. :roll: Think i'm going to be driving the van for a while
^^^ that was yesterday.
Hmm, so much for my hopes of finding some dead bushes
£65 exchange from the local autoelectrics place. Bah humbug!
And then i've still got to sort the fueling problem!
