Oh dear artifacts!
Caporegime
8 Sep 2006
On Ocuk
It might be related to the latest beta drivers but I'm noticing some oddities on the desktop(Ocuk Forum) and in game text. White lines that shimmer and flicker from right to left. Clocks and Memory at stock!
It also doesn't show using Msi Afterburner, anyone else had this with the latest betas? I'm going back to the officials now :eek:
No artifacts for me on 13.12 WHQL. What browser are you using? Chrome ftw.
Ok I'll go back to 13.12!
Firefox, however as I said it was doing it in games as well.
Here's an example
Here's an example
Other than disabling hardware acceleration on firefox, no idea. Possibly a faulty card. However that can also be caused by an unstable overclock.
^ No MSI R280X
But it needs to be enough to send it back as it's not doing it all the time, just loaded up Skyrim and it's not doing it now. What's a good app to put it through as I haven't seen it through valley
You should have just DSR'd it when we realised it was voltage locked.
The reason I didn't do that was because it was working fine, at the time. If I had sent it back, got a new card that was still voltage locked or was borked that would be even more money. As someone said, why send a working card back :p
But now :o
But now :o
Its not normal for a Tahiti card to be voltage locked typically, so you would've been within your rights. If you'd known it would be locked, you would not have bought it, would you? I don't condone DSR'ing for no reason, but if you have a legitimate reason then its fair game as far as im concerned.
Just loaded Skyrim about three separate times and it's not doing it anymore!
To be honest this all started after install the latest beta drivers.
I'll keep an eye on it, if it does it again I'll put it on record via my mobile and send that as proof! I know what ocuk are like for sending back items that don't work
Yeah you need to be 100% sure.
