- 6 Dec 2007
- Dewsbury
Hello all!
Well, I've been having a load of luck lately. After rehousing my PC into a new case, I was faced with a PC doing nothing at all when switched on. After examining the motherboard, I thought that it was at fault (had a burst cap), and rather than try to fix a 775 board, I went for a full socket 1155 upgrade (CPU, RAM, mobo).
Now then, fast forward to tonight when I took delivery of an extension cable, allowing me enough room to re-fit my BFG GTX275, annnnddd... blank screen. I'm really hoping I didn't spend £334 for nothing, but it's looking likely at this point. PC works fine when set to integrated graphics, but when the GFX card is in the slot and plugged in etc, I just get a blank screen. I assume that the motherboard is seeing a card and putting signal through the slot regardless of whether it's working or not, but nothing is getting to my monitor. I could never check this with the old motherboard as that didn't have any onboard graphics, and I didn't have any spare cards
If I took apart the GTX275, is there any chance of me being able to do any fixes, or should I write it off and think about getting a new card? If so, is there anything sub £150 that will give comparable, if not better, performance? I game at 1680x1050, currently playing games like Dark Souls, Witcher 2, ARMA 3, BF3 and (rather shamefully) TrainSimulator 2013.
EDIT: I tried the monitor cable in both DVI ports on the card, neither of them worked.
(BF3, GRID, Borderlands 1 and 2, Crysis 1 and 2, Mass Effect 1 and 2, Morrowind and Oblivion both modded to the hilt and Skyrim, The Witcher 2 - not exactly lightweight games!)
