Oh Look another spec check.....
12 Oct 2003
B'ham
After struggling along with my current setup I thought the time has come to order a new pc. Have been browsing the forums and have come up with this lot. I want the pc to be quiet as possible, so was thinking get a P180 and Seasonic psu or get the SonataII and save a bit of money..
so can someone just check this lot over and just confirm that it is a good choice and that everything will work fine...
CP-150-AM AMD Athlon 64 3700+ San Diego 90nm (Socket 939) - OEM (CP-150-AM)
£122.95 £122.95
MB-111-AS Asus A8N-SLi Premium nForce4 SLi (Socket 939) PCI-Express Motherboard (MB-111-AS)
£104.95 £104.95
MY-007-GS G.Skill 2GB DDR ZX PC3200 (2x1GB) CAS2 Dual Channel Kit (F1-3200PHU2-2GBZX) (MY-007-GS)
£129.95 £129.95
HD-070-WD Western Digital Caviar SE16 320GB 3200KS SATA-II 16MB Cache - OEM (HD-070-WD)
£79.95 £79.95
CD-033-PO Pioneer DVR-110DSV 16 x 16 DVD±RW Dual Layer ReWriter - (Silver) OEM (CD-033-PO)
£24.95 £24.95
HS-025-AK Akasa AK-920 EVO 120 Direct Heatpipe Copper with Fan Controller (Socket 754/939/775/478) (HS-025-AK)
£29.95 £29.95
GX-048-PC PowerColor ATI Radeon X1800 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-048-PC)
£229.95 £229.95
CA-039-AN Antec P180 Advanced Super Midi Tower Case - No PSU (Silver) (CA-039-AN)
£74.95 £74.95
CA-000-SS Seasonic S12 430W Silent ATX2.0 Power Supply (CA-000-SS)
£52.95 £52.95
Subtotal £850.55
VAT £148.85
Total £999.40
Oh the rig will be mainly used for playing games
Thanks
Tom
All the parts are compatible, you can get cheaper motherboards but I assume that the silent heatpipes are attracting you to the Asus premium. You could consider a Silentmaxx enclosure or similar for the hard drive to get it even quieter but other than that I'd say go for it.
Thanks for the comments, I will be getting the new Zalman for the graphics card and I will look into the hard drive enclousre also.
Do you think the P180 is worth the extra or is a it a fair bit quieter than the Sonata, but maybe the extra case fans will help due to the fact I will be overclocking?
I have the P180. I can't compare it with any other 'quiet' cases but I think its pretty good. I chose it because I wanted quietness and a cool system and its doing the job great.
Ok cheers looks like I will go for the P180
Just one more question: Is the Evo 120 any good or is there better, quieter coolers available in the same price range?
TIA
Just to let everyone know, I have now ordered all my stuff
cant wait till it all arrives (hopefully tomorrow)
Thanks for your help
