oh **** need help big problem
22 Nov 2009
Cornwall
i have just installed windows 7 and it was working fine for about 10min then the screen when black and the cpu fan and graphics fan went on overdrive.
i turned the pc off now when i turn it back on nothing comes up on the screen and the cpu and graphics card fan dont turn on. helppp plsss
Check all power connectors are tight & check all components.
Try doing a CMOS reset and try with only one memory module.
amd phenom II x4 955 be
ati hd 5850
sliverstone strider 750w continuous
Western Digital Caviar Black 640GB SATA-II 32MB Cache
OCZ Obsidian 4GB (2x2GB) DDR3 PC3-12800C9 Dual Channel
