Oh the irony.. my site doesn't work in IE8
9 Jun 2006
Purgatory
http://sebcastilho.com/
I've tested it in Firefox, Chrome, Safari, IE6 + 7
But then I decided to download IE8... and low and behold I get problems!
Try pressing the "Sign Guestbook" link and it doesn't work! In fact if you try highlighting the text, it highlights the bio stuff instead.
Also, in other browsers when you hover over a thumbnail the cursor will change to magnifying glass, but not in IE8...
Any ideas?
Does changing to IE7 mode fix anything?
Code:
<meta http-equiv="X-UA-Compatible" content="IE=7" />
Obviously you want to fix the problems, but just to get it working asap it's worth a try.
Ah yes that will do for now until a proper solution is found :)
I'm guessing the overhauled the render engine then?
