Oil consumption and distance between max and min
12 Jul 2007
South East
Hi all,
Had the oil changed in my Accord back in May and when checking it on Sunday, the level was half way between the min and max mark on the dipstick. I believe it was at the max mark after the oil had been changed.
Is it normal for VTEC engines to consume a little oil? What "amount" of oil is the distance between min and max generally? Am I worrying over nothing? ;)
I've done about 4.5-5k miles since it was changed.
I'm only curious because it contrasts with the MX-5 which uses absolutely no oil even given the amount of hoonage partaken with it :p
Cheers :)
