If you submerge your PC in chilled oil, you'll still need to ensure that's it is air tight, otherwise you'll still get condensation forming and ending up in the oil, worse than that the oil will almost certainly be less dense meaning that the water will sink down to the bottom and stay there.
You'll also end up getting condensation forming on the outside of the case, mean soggy carpets/wet desk.
