You are looking for a tin can basically that is painted, hopefully white with red stripes but it could be black or grey or god knows to be honest. I honestly can't remember exactly where it is on a Corsa. Probably at the back but if you look low on your engine from below and from the top looking down the back of the lump you'll see it.
Looking at the amount you dropped in half and hour it should be quite obvious where it's coming from. Get a cardboard box rip it up flat then lay it under your engine. Lift the bonnett to improve light and lay under the car looking for the trail of oil. Look about for the Oil filter while you are down there and when you find it just grip it with your hand and see if it is tight & whether there is an oil trail.
Took the car to my step-grandads and it seemed it was some kind of valve near the gearbox that relieved pressure, it was blocked so oil was being forced out of the seals occasionally. All nice and clean now so it should run fine. Thanks anyway.
