- 24 Apr 2020
Hi.
My oil level sensor in my sump was playing up.
So bought a genuine VW replacement double checked the part number all match up perfectly.
Went to fit the new sensor today the old came out so easy but I'm having trouble fitting the new one the sensor part that's goes up into the sump just won't go, doesn't seem to line up.
I'm confused as it's 100% the correct part any body else had this issue?
Mk5 golf GTi 2006.
Thanks
Mk5 golf GTi 2006.
Thanks
