Oil Question
28 Jan 2005
Southport
Hi all,
I have just checked my oil level and I noticed that on the dip stick it had the thicker ‘gunky’ stuff on it, the same as you get under the oil cap( only a bit tho). Now is this normal? I have been away for a week and my car has been unused on the drive if that makes a difference.
It’s a Corsa and im using the magnitec oil stuff.
Thanks
