I may be in the wrong place for this but if anybody has any info it would really help!
I am trying to install Linux to a PC which I have knocked up very quickly to run windows (which runs fine). So I go to install it (which it does... no error's) and at the end of the install do as it shows. Take out the CD and hit enter to reboot. HDD-0 is the first boot device (worked for windows) and yeh it displays that it cannot find the boot info on the HDD. Perhaps I need a boot loader? If this is the case then I have never used one and would like some advice in how to use one.
Thanks all!
Thanks all!
