- 2 Jan 2004
- Exeter, Devon
Hey all,
I've been trying to get to the bottom of this for a few weeks now, but I'm finally gonna have to admit defeat and turn to you guys.
Basically, a few weeks ago during a game of 2142 my PC froze up completely, and required me to do a hard reset. POST was fine (if perhaps a little slower than usual) but it took quite a while for the Windows XP loading screen to appear.
Hmm, I thought, that's strange (every PC I've built in the past has been rock-solid, and even this one has been fine for the last 4 months or so that Ive had it). Anyway, did a virus scan which came back negative, so I decide it could well be a problem with the new mixture of graphics and sound drivers Ive been messing around with. I formatted my boot HDD, everything goes fine, get into Windows again for 30mins and it locks up again.
Since then it's been freezing up (seemingly) whenever it feels like. Whether it be while I'm browsing the net, listening to music or whatever. I can play (for example) 2142 for a bit no problems, then go back into Windows and it will die as soon as I use Winamp, or Thunderbird or anything.
Anyway, I've checked the usual things. Eventvwr says nothing (except for a very occassional moan about my DVD/RW drive which I assume is a coincidence, it doesn't always coincide with a lock up), tried a friends RAM which worked fine for hours (though 2142 was a bit screwy, which I attributed to only using 1gig rather than the 2gig its set to expect) then locked up as I was burning memtest, run memtest on my memory for 14 odd hours with NO errors. Checked my case for dust (practically spotless) and did the hand-on-heatsink trick, no problems there. Also did a chkdisc on my boot drive which didnt come back with anything either. Voltages in BIOS seem stable enough to....
...so, I'm stumped, and very, very irritated. I'm pretty close to forking out for a new PSU to see if that makes any difference, but I can't afford to be wasting money on the wrong thing!
Specs:
AMD 3700+ SD 939
Asus A8N SLI SE
2gig (2x1) Corsair TwinX DDR 3200
Sapphire X1800XT
2x 160gig WD SE IDE HDD
NEC DVD/RW
Hiper 580w -r
Specs:
AMD 3700+ SD 939
Asus A8N SLI SE
Sapphire X1800XT
NEC DVD/RW
Hiper 580w -r
