OK! im about to buy water cooling rig, need final quick advice!
1 May 2003
Peterborough
right just need a quick yes no really on this cooling rig
do you think the:
Swiftech H20-120 Premium Watercooling Kit
- Apogee waterblock
- MCR120 Radiator
- MCRES1000P
- MCB120 Radbox radiator mounting adapter
- 7/16" ID Tubing
- Adjustable pump speed
Full Specification
Price: £105.95 (£124.49 Including VAT at 17.5%)
will outperform a scythe mine/ninja and an arctic cooling 64pro?
ill be buying in the next hour, hope peeps can help!!! ;-)_ cheers!
good choice , i would suggest getting bigger rad 220 if you plan to overclock.
is this a kit and what cpu u cooling?
it should out perform them on load temps
im cooling an opteron up 170 ive seen it prime stable at 2.8ghz and 1.5 volts
and was cooled by a thermaltake hsf,
i will probably upgrade the rad in the future, but do you think this will be a good kit to cool the opteron at those speeds?
would the swiftech premium kit outperform the best air coolers out there?
say the tuniq tower and all the others?
just wanna know if its worth it?
ill be ordering in 20 mins
Yes it would, but I'd want a 120.2 rad.
me too, but i cannot afford it at the moment, plus i dont think it will fit propperly to tha back of my case without it getting in the way of the dvi port on my monitor
To be honest, I'd probably go with a Tuniq Tower and save £100, put that towards a future upgrade.
