Hey all I am still trying to get better performance out of this game.
I know its a demanding game and to be honest could be tweaked to make better use of hardware.
Any ways I am in the process of trying to get it to run better.
I purchased a 4890 1gb a while ago and it helped BUT I think my Q6700 at std clock speeds is holding it back.
The reason I say this is because in some missions I am getting 20fps (most of the time 30-50fps in some missions) if I look up or where there is no major rendering for the GPU to do it will either stay at 20fps or some times go to say 25fps depends on scene.
Now the only thing I can think of is the CPU is this a bottle neck in my system now?.
And it does seem to lag a little more when the AI engage.
So will an over clock help I really want to hear from others with the same kind of spec system and if they have over clocker there Q6700 and if it made a difference in ARMA2.
System spec
Asus striker extreme 1
Q6700
4gb ram
ATI 4890 1gb
crappy hard drives (need new ones they dont help the problem as this game streams large amounts of data)
Thanks all
System spec
Q6700
4gb ram
ATI 4890 1gb
Thanks all
yep demanding game.
