Ok - next problem with "Primo Pro"
4 Sep 2008
Hi guys
Got one of these for my son going to uni next week - tried to fit a 8800GT (Leadteck) for him - it worked work a while.
Just long enough to load all the machines OS new XP Pro + drivers and play 1 quick game of Medevil 2 that does 60 fps for about 10 sec then 1-2 fps for 5 sec - :(
so I thought
Ahhh - OcUK supplied wrong mem - 5400 instead of 6400 - they replace V quick excelant service.:)
Booted with new ram - bril - ME2 does 1 min on 60fps and then 20 sec on 1-2 fps:confused:
Um - DEBUG TIME - take stick of RAM out - (just to start eliminating things) - Machine won't post - strange
Swapped RAM sticks - machine won't post
Took GT card out and pluged into onboard VGA - Machine won't post
Reset the BIOS back to factory (Battery out etc...) - Ah machine posts and uses VGA
Put GT back in - machine won't post
Took GT out - reset BIOS - put GT in - Ah posts but no output from GT
I think two things are wrong
1. GT card has failed
2. GT card in failing has taken MOBO with it
Every time I switch on the BIOS need reseting - not a good thing for my son to be doing
Any suggestions before I send MOBO and GT card to land of RMA (That will be the whole machine [bar the case])
Its the power supply mate, its only 250w and no good for an 8800GT
Edit, Actually i though it as one of the asus barebone type builds.
Still sounds like PSU tho, any idea what make/wattage it is?
EDIT2 : Is it this sytem here?
http://www.overclockers.co.uk/showproduct.php?prodid=FS-085-OK
If so then i was right first time, the PSU isnt up to the job. Also i assume you connected the 6pin PCI plug to the card? youd have to use an adaptor as the PSU dosent have one of the 6 pin plugs you need
Well - i didn't mention it in the main post but I put in a 400w Jantech ATX (powered my rig for years) to eliminate that possibility because when I got the system I thought exactly the same as u
And Yes it is that one in the link with 500gb option
