ken1307 said:sorry for OT but locutus12, thats site is AWESOME !!!
about the gfx, just test it with atitools to check for artifact (sp?), if the card is borked then it will have artifact even at stock clock
i have played it in safe mode which runs fine as all the advanced features of the Gcard are dissabled. but come into a fully powerd graphical environment and youl have no such luck.
mosehn said:whats the big rush to not have a gfx card for a couple of weeks?
locutus12 said:a quick update... after working on this for 3 hours ive found that by turning off the ATI hotkey poller the flickering log in screen has now gone. unfortunatly the crashing with office and flash based website remains, ive tried them in both fire fox and internet explorer with no luck, i get a blue screen error after about 30 seconds.
mosehn said:so what do you want us todo , you dont seem to have the patience to send it back and wait for a replacement because you only have 1 gfx card ,
Metallifux said:Probably completely unrelated, but what mobo do you have? I have an asrock dual sata2 and had a bsod problem with office. Turns out it was 1T command rate on my ram, everything else worked fine. No artifacting though.
Cyber-Mav said:last time i heard about someone cahsing in office apps and flash based sites it was command rate related on the asrock boards. if 1t command rate is unstable then in occie a simple copy/paste would crash the machine and so would flash based sites.
Richdog said:Hooray for Mav... glad I was wrong in this case I would never have thought of a fault specific to Asrock like that.![]()
