ok problem i need help plz
15 Feb 2009
ok its like this....BF BC 2 crashs with no event log?
tropico 3 crashs, both crash with nvlddmkm error...this is event log for tropico 3
Faulting application name: Tropico3.exe, version: 1.0.275.18874, time stamp: 0x4aa044ff
Faulting module name: Tropico3.exe, version: 1.0.275.18874, time stamp: 0x4aa044ff
Exception code: 0xc0000005
Fault offset: 0x00199548
Faulting process id: 0x1d4
Faulting application start time: 0x01cad2f219711380
Faulting application path: C:\Program Files\Kalypso\Tropico 3\Tropico3.exe
Faulting module path: C:\Program Files\Kalypso\Tropico 3\Tropico3.exe
Report Id: c679de80-3ee6-11df-a5b1-001e8c1c6c75
Windows cannot access the file for one of the following reasons: there is a problem with the network connection, the disk that the file is stored on, or the storage drivers installed on this computer; or the disk is missing. Windows closed the program Tropico 3 because of this error.
Program: Tropico 3
File:
The error value is listed in the Additional Data section.
User Action
1. Open the file again. This situation might be a temporary problem that corrects itself when the program runs again.
2. If the file still cannot be accessed and
- It is on the network, your network administrator should verify that there is not a problem with the network and that the server can be contacted.
- It is on a removable disk, for example, a floppy disk or CD-ROM, verify that the disk is fully inserted into the computer.
3. Check and repair the file system by running CHKDSK. To run CHKDSK, click Start, click Run, type CMD, and then click OK. At the command prompt, type CHKDSK /F, and then press ENTER.
4. If the problem persists, restore the file from a backup copy.
5. Determine whether other files on the same disk can be opened. If not, the disk might be damaged. If it is a hard disk, contact your administrator or computer hardware vendor for further assistance.
Additional Data
Error value: 00000000
Disk type: 0
also getting
An error was detected on device \Device\Harddisk1\DR1 during a paging operation. dont understand that
and the last thing....looking at the video card tuneing and core bus is 0mhz?
and memory bus is 0mhz :/
a screenshot of my video card below
http://img229.imageshack.us/img229/5949/erroryj.jpg
I assume looking at that screenshot it just shows you the value of how much it is overclocked over the stock speeds. What card is it? And it looks more like a problem with the game, not the card. Try play other games and see if you get the same problem. If it only happens with that game, then try reinstall it.
