OK, recommend me a case
13 Sep 2009
Telford
I'm building a new PC before Christmas, but I'm not sure what case to go for.
My requirements are:
  • Some sort of midi case (i.e. 4*5.25" bays, etc)
  • Standard ATX
  • Not too expensive, but I'm flexible
  • Relatively simple aesthetically - I'm not one for big neon windows and such (my current case is a Coolermaster Praetorian (without the window) ffs)
  • Easy access for maintenance - current case is pretty much a straight metal chassis with a removable mobo tray - would like to have easy change 3.5" bays etc
  • Good clearance for GFX cards - current card is only 660Ti, but I'd rather not have to remove all my HDDs if I get a longer card - current case can be very awkward in that respect
  • Decent enough (quiet) cooling - I'm not going to be overclocking though
Hope that gives you a good enough idea. Your suggestions appreciated!
Thanks for the suggestions.
In terms of budget, I'm fairly flexible - I know the case will last me a long time, so I'm happy to put a bit more money into it. No more than 125 though really. Also this is too expensive ;) ;)
