Ok temp?
Don
23 Oct 2005
North Yorkshire
Right everything seems ok now with my PC.
The spec is:
Amd x2 64 4400+
Asus A8N32-SLI Deluxe
Ati X1900XTX
Ocz 2GB RAM
x2 160gb SATA2 hdd's
Hiper Type-R PSU
Tai-Chi case with stock watercooling.
x3 Akasa amber 120mm fans
CPU is at 36oC
Motherboard at 37oC (This however can get up to 45 sometimes!)
Does this seem all ok, no overclocking has been done (yet)
Thanks!
Seems ok to me, your about half way to the limit on the cpu, your fine for +20 degrees, regardless of what others say its perfectly fine up to there, I ran my dual core at that for half a hour when i had a kink in my tubing for the reserator.
