Well, after a good time of ownership, good enough to realise the ins and outs of it... I have decided I want rid of this TJ09. Reasons for this are:
So... with that in mind the time has come for me to downgrade in size and inconvenience... but not in terms of quality. My new case needs to have the following assets:
I've been looking at the following:
Lian-Li PC-A05B http://episteme.arstechnica.com/eve/forums/a/tpc/f/77909585/m/319001496831
Looks like it pushes all my buttons... very sexy case... the only problem I can see being the top pocket of heat at the top of the case due to the way the fans are arranged (back is intake, front exhaust, both quite low down). However looks like an awesome design and really small yet conveneint to work with. If I could mod the top to accept a 120mm fan I think that would work wonders for it.
And er... that's the only one I can currently find which ticks the boxes. Any other suggestions guys?
- It's huge... heavy... takes up WAY more floor space than I actually need.
- Rattles like no-ones business... i've never been able to get rid of it and the noises drive me mad. Not what I expected from a £190 case.
- The centre GPU fan is also very noisy... I wondered why I could still hear a lot of fan noise form my system even with everything else turned to minimum and then decided to test it with the centre fan disconnected and hey presto... near-silent PC. It's also a beeyatch to change, requiring much fiddling which I quite frankly can't be ringed to do.
- Too many fans... a total of 5 120mm fans is just overkill, and the cooling benefits probably aren't a mile over a good 2x 120mm fan case with good airflow design.
- It has bay slots, a drive cage, and oodles of space I will never use... so what's the point in having it.
- Black, because black is cool.
- No front door. Front doors are gay.
- Relatively small size but accept ATX mobos.
- Decent airflow, not too many fans.
- At least 2x 5.25" and 1x 3.5" slots at the front.
- At least 3x HD capacity inside.
- Can fit a large single graphics card.
- Can fit a large CPU cooler (120 Extreme).
