Ok whats wrong with my Gigabyte DS4 now???
29 Oct 2002
stoke-on-trent
Working ok yesterday this morning when I switched on the fans spin for about 1 second, then power down, then the cycle repeats?? System does not want to go any farther????? Anyone any ideas, I have the latest bios.
Try clearing the CMOS?
Did you install anything that may have an effect like this the last time you used it?
Check all the connections as something may have come loose in the night. Try reseating the RAM.
I was playing about with some settings in the bios, so reset bios and it seems ok. Must have left one reset last night.Sorry panic over.
my ds4 would do that. Could set settings in bios, reboot and run prime for hours on end so was stable but soon as i switched it off for a length of time like over night it wouldnt boot again in the morning. Just power on, power off, power on power off :mad:
